I wanna get a new laptop for using for djing with virtual dj anyone recommend a gd one to go with and will i need a usb sound card as well if i want to record my set ?
Here is my setup
2*cdj 2000 and a djm 400 mixer + virtual dj
Here is my setup
geposted Fri 18 Jan 13 @ 12:56 pm
What's your budget? Are you after Mac or PC? What screen size do you want?
geposted Fri 18 Jan 13 @ 5:25 pm
I dont have a budget but i do want a pc rather than mac since i dont like macs , screen size does not mater but a big one is a +
geposted Sat 19 Jan 13 @ 7:54 am
jag4life wrote :
new laptop
Do you play videos or just mp3?
Do you want to stick with Win7 or go to Win8?
I like any of the gaming laptops, they seem to have the highest specs, especially for doing video. Check out MSI and Asus but beware of getting something with all USB3's.
Another alternative for a great machine is a Mac Book Pro bootcamped with Windows.... best of both worlds!
geposted Sat 19 Jan 13 @ 8:47 am
Will I be be able to play audio and mix video simultaneously with the following laptop.
Toshiba Tecra R940-SMBN23 Laptop.
Intel® Core™ i7-3520M Processor, 2.90 GHz (3.60 GHz with Turbo Boost Technology), 4MB Cache
Windows® 7 Professional (64-bit) with recovery media for Windows 8 Pro
8GB DDR3 1600MHz (4GB + 4GB)
750GB HDD (5400rpm, Serial ATA)
1GB DDR3 AMD Radeon™ HD 7670M Graphics
14.0" HD+ LED Backlit Display (1600x900)
Integrated 2MP Webcam and Microphone
Enhanced Lithium-Ion Battery (9-cell, 93Wh)
Intel® Centrino® Advanced-N 6235 (a/g/n)+ WiDi Capable with Bluetooth® (v4.0)
MacBook Pro
2.9GHz dual-core Intel Core i7
Turbo Boost up to 3.6GHz
8GB 1600MHz memory
750GB 5400-rpm hard drive1
Intel HD Graphics 4000
Built-in battery (7 hours)2
Thanks.
MacBook Pro
8GB 1600MHz memory
Thanks.
geposted Sat 19 Jan 13 @ 8:48 am
have a look at asus gaming machines
geposted Sun 20 Jan 13 @ 7:26 am
