as the topic says, has anyone got a solution?
I've started mapping my xone dx for VDJ PRO to take full advantage of the controller and when i got to the led mapping, i get an error sound in my default sound card.
example: i activate an effect or chose the pfl... the led turns on and you hear the sound one time when assigning "on" to the led. I assign "blink" for the play or other actions to notice me that a second effect is on, and i get a sound everytime it blinks.
geposted Sun 20 Jan 13 @ 10:22 am
make sure in your definition that you are identifying the controller, either using sysex or drivername, otherwise MIDI notes will be sent to all MIDI capable devices.
geposted Sun 20 Jan 13 @ 12:13 pm
Thanks, solved it! :)
geposted Sun 20 Jan 13 @ 12:37 pm
