i dont know if i should post this in the 7.3 topic but ive been using the same setup for a while now and suddenly when i have all my controllers connected the tracks are playing a few milliseconds slow,its not enough to change the bpm of the songs but when you listen you can hear the difference in speed, has anyone had this issue or know how to remedy it? like i said ive been runnign the samesetup for a while and its only recently im having this issue
geposted Tue 22 Jan 13 @ 4:05 pm
Try turning off auto pitch matching and manual beatlock in your setting
geposted Tue 22 Jan 13 @ 5:16 pm
thanks, i already had autopitch disabled but now have disengage beatlock on load, i wont be able to test this till later so i will get back and let u know if it worked
thanks
thanks
geposted Tue 22 Jan 13 @ 5:46 pm
i checkec with beatlock disengaged on load and autopitch off but im still having the same issues tracks arent playing at normal speed
thanks for the suggestion though
geposted Tue 22 Jan 13 @ 6:31 pm
