Forgive me forum as I cant find this post in the topics, but I remember seeing a script or action in the registry that I could use to change the cossfader behavior back to the way it was prior to the recent update(s) Version 7.......My Xfader now will not "fade" the other deck out as I move it across, it instead leaves the deck I am fading out of at the same volume until the fader is 100% on the other deck side.......Why would anyone want this and how to I go back to the classic crossfader behavior?.....thanks as always.... =D
geposted Tue 22 Jan 13 @ 4:13 pm
You can select the crossfader behavior by selecting a different Crossfader Curve.
Config-->Options tab -->Crossfader (choose from Smooth, Cut, Scratch, Full, disabled)
geposted Tue 22 Jan 13 @ 7:11 pm
jusblaze246 wrote :
B]Why would anyone want this and how to I go back to the classic crossfader behavior?
Well, scratchers use this alot. So the don't have to move the CF all the way to the other side to enable the second deck.
But in case you really want to invert the crossfader behavior use the registry tool. I think there is a checkbox to enable/ disable "hamster mode"
geposted Wed 23 Jan 13 @ 6:49 am
