So to all you musically inclined individuals out there: I need some help.
I know nothing about music, except for that I can make a pandora station and set my radio channels in my car.
My husband and I are renewing vows (no ceremony or anything, just giving each other our written vows on a trip), and I wanted to do something really creative that he would love.
He knows a ton about music and I thought it would be really cool to make a song from a bunch of love-ish songs. Like Naked Eyes' - There is always something there to remind me and Alanis Morissette's - Head Over Feet.
Anyways, any help with this would be awesome, like I said before I am clueless about any of this, but I know he would be impressed and I can't think of a better way to give him vows. I don't know if Virtual DJ is the right software for this and if I can be pointed in a general direction, that would help a lot.
Thanks in advance.
-Kim
Thanks in advance.
-Kim
geposted Wed 23 Jan 13 @ 3:23 pm
you can check something like audacity,its a little complex but if you check some tutorials on youtube you would be able to make a mix that would kindof belnd the songs into a a mix that is a few minutes,id just at least check it out cause its a free program,VDJ is great and im not trying to stear you away from it but it might be more then you are looking for in the long run
geposted Wed 23 Jan 13 @ 3:53 pm
Virtual DJ is more then enough to satisfy your and his musical palate in the way you want to use the software, so first you would be sellecting your music and mix each track from two decks the way you would like it, when ready go the the record tab in virtualDJ Click on "Config" Give it a file name, click "OK" and press the "Start" button.. Now start your music mix while it's recording.
Once your done make sure you go back to the record tad press "Stop" then go to"Config" and Click on the little box to the right of the file name box and click save... (If You Don't do this your recording will not be saved and you'll lose this recording when you shut down)
Good Luck
Good Luck
geposted Wed 23 Jan 13 @ 4:19 pm
Thanks Yall!
I'm going to follow the steps on a "trial run" and see if I can operate it correctly. I'm also going to check out audacity to see which I am better with. Great advice on the youtube help videos. I'm definitely going to check those out too.
geposted Sat 26 Jan 13 @ 6:26 pm
