I have a question for you guys. I bought the virtual dj iremote on itunes now I'm trying to change the skin and not quite sure how to change it on my ipad. Thanks for info you guys can help with.
geposted Sat 26 Jan 13 @ 12:41 pm
You need to go in to the config menu and go to the ipad/iphone and connect your pad to the software then send the skin from VDJ to your ipad.
geposted Sat 26 Jan 13 @ 12:52 pm
Yep that would be the question, how.
geposted Mon 28 Jan 13 @ 12:34 am
Have you looked in the FAQ, specifically here?
https://virtualdj.com/wiki/How%20do%20I%20install%20a%20custom%20iRemote%20skin.html
geposted Mon 28 Jan 13 @ 1:34 am
Thank you
geposted Mon 28 Jan 13 @ 9:46 am
