Forum: Old versions
Topic: Setting conflict?
Quick question.....When I record a mix using my VMS4, I hear the music from my headphones on the mix as well, but the audience cannot hear it. I want the music that the audience is listening to to get recorded to the mix, not what I can hear on my headphones as I am preparing to transition songs. Does this make sense?
geposted Mon 28 Jan 13 @ 2:49 pm
Ive tried this page, but when I change the outputs to advanced config, the music doesnt go through my speakers anymore....
I am getting closer to a solution. I can hear the music that the audience hears and not what is coming out of the headphones, but the sound quality being recorded is not that good. I have tried switching the Record Loopback to ADJ ASIO (ASIO) but when I play back the recording, there is no sound. It only seems to play back when I have the record loopback on Microphone. Is there something that I am missing?
I have 2 Decks being used.
My settings are as follows:
Deck 1-ADJ ASIO - Output 1 & 2
Deck 2-ADJ ASIO -Output 3 & 4
Record Loopback - Microphone (High Definition Audio Device)- Input 1 & 2
Thank you for your help!!!
The poor quality will be due to using a microphone input. A line level signal will be too high for a microphone level input and will sound distorted. It will also in most cases be a mono input rather than stereo.
If you are using a desktop PC, make sure that you use its sound card's line input socket (If it has one), not microphone.
If you are using a laptop, then in many cases they have a combined mic/line input. Have a look in your sound card or operating system's audio control panel to see whether you can switch this to a line input.
Otherwise, purchase an external USB sound card that has a line input socket and use that for recording.
NOTE: The full VirtualDJ Pro is required to use advanced sound config outside of the 20 day Pro trial: https://virtualdj.com/buy/ - If you don't want to upgrade yet, then you can use 3rd party recording software such as Audacity to do your recording instead of the internal recording facility in VirtualDJ.
