Hi I'm using virtual DJ LE and once I open up the software not all of my music shows up in its appropriate folders..... Like if on my external drive I have a folder tittled BLUES. Well when I open the folder in virtual DJ only some of the music shows up...any suggestions
geposted Wed 30 Jan 13 @ 7:15 pm
Try this, go to Config and open the Browser tab choose your external drive letter in the "Drive" box, then Check, Clean and Fix.. See if that helps, also what type of files do you have in that folder?
geposted Wed 30 Jan 13 @ 7:45 pm
You can also go to the left panel in VJ and expand the My Computer menu, then click on the drive you want to add, then right click and choose add to search DB.
geposted Thu 31 Jan 13 @ 11:45 am
