Forum: Old versions
Topic: cue over lapping?
i was curious if this was possible, i notice that i can map a key to play a cue only while its pressed, and it will keep the track also playing its normal state then pick back up when i release the momentary cue. i guess what i'm wanting to do is be able to play 2 cues at once, i figure as of right now this isnt possible or i just don't know how to write the script correctly. maybe an added feature in 8?
the main problem im having is when im going from cue 1 to cue 2 (two seperate buttons) if i don't entirely let go of cue 1 first, it won't play cue 2. kind of preventing me from creating a seemless transition
if anyone can help me out that would be great, i did a few searches but didn't come up with my answer
cheers-
geposted Thu 31 Jan 13 @ 11:52 pm
Hot Cues don't work this way. That's why you can't get the results you want.
There's only ONE needle position (playing head) per track and thus you CAN'T force the track to play from two locations on the same time.
you could slice your song up into samples and use the cue macro plugin to load the samples when you load the song onto a deck.
or you could get tricksy, it queries if the other button is pressed, if so it does nothing on release... You can do it for as many cues as you like.. on my iDJ mapping it was done for 8 cues ;-)
cue 1 button
set 'cueOneDown' while_pressed & down ? goto_cue 1 & play : var 'cueTwoDown' ? nothing : var 'cueThreeDown' ? nothing : pause & goto_cue 1
cue 2 button
set 'cueTwoDown' while_pressed & down ? goto_cue 2 & play : var 'cueOneDown' ? nothing : var 'cueThreeDown' ? nothing : pause & goto_cue 2
cue 3 button
set 'cueThreeDown' while_pressed & down ? goto_cue 3 & play : var 'cueOneDown' ? nothing : var 'cueTwoDown' ? nothing : pause & goto_cue 3
etc... If you want to add more you just need to append the teal part with the other cueNumberDown variables
