Hi guys,
Im new to all this and looking to buy a budget controller to use with virtual DJ, i just wanted to get a few of your expert opinions before i spend the cash.
The main 2 ive been looking at are the Denon MC2000 and the Numark Mixtrack Pro 2.
Is the MC2000 worth the extra money(£50 more) than the Mixtrack Pro 2 ???
Which one has more features or are they roughly the same with build quality the only main difference ???
If there are any other suggestions you guys have for a controller please let me know.
Thanks for reading :)
geposted Sun 03 Feb 13 @ 10:23 am
Both are pretty weak in my opinion but you should go to a store that has them and try them both out. Heres some reviews,
I'd go with the Stanton DJC.4
Eitherway Id try them all out first hand............ Good Luck
geposted Sun 03 Feb 13 @ 10:33 am
