Hope some one can be of help with my issue of the Rhythm window display scrolling across the screen in a choppy/jumping manner? I have tried all the different screen settings on laptop and in VDJ with no luck. (all other operations fine & sound great) [Running VDJ 7.2 on windows 8 with upto date updates on fresh machine with no other software loaded and av disabled on a Acer 6930G, Intel Duo 2.13ghz, Ram 4g ddr2, Vid 2303mb] Cheers.
geposted Mon 04 Feb 13 @ 1:17 pm
This is most likely caused by video performance issues. Please see https://virtualdj.com/wiki/My%20video%20output%20runs%20slowly%20or%20is%20very%20choppy.html
Also, see: https://virtualdj.com/wiki/Performance%20Issues.html
You may also get this issue if you have resized or maximised the skin. For best results, make sure that you use a skin that is the correct resolution for your screen (So resizing/maximising is not necessary.) Custom skins in a wide variety of sizes can be download from https://virtualdj.com/addons/skins.html - They can also be resized using the skin resizer tool.
geposted Tue 05 Feb 13 @ 5:07 am
