I'm using a APC20 and have ALOT of filter folders broke up into several catagories (i.e. Progressive House). I'm wanting to map buttons to load a certain filter folders into the browser window and if that certain filter folder is in the browser window have the button "blink" otherwise have it "off". Been reading the forums but haven't seen this topic. I've tried using virtual folders but doesn't seem to work that well.
Any Suggestions???
Any Suggestions???
geposted Fri 08 Feb 13 @ 12:00 pm
Nevermind GOT IT!!
I had to use Virtual Folders anyway.....Map the button to '"browser_gotofolder" X & set "mode" X' and map the LED 'var_equal "mode" X ? blink : off'
There's prob. an easiler way but I usually take the long way around things....Thanks for reading anyway
geposted Sat 09 Feb 13 @ 11:30 am
Have you got your APC20 LED's to light up when pressed? Or do u use it with the "generic" xml? If you have the mapping for the APC20, is there any chance I could grab it from you? I'm not expert when it comes to mapping. I've tried to change the APC40 mapping found on the V DJ web site. But I just got lost.
Cheers
Cheers
geposted Thu 14 Feb 13 @ 1:58 am
