So I just bought the American Audio VMS2, and I got Virtual DJ LE with it. But there seems to be a problem, the crossfader thingy doesn't work. When I have the fader all on side A I can hear both deck A and B but when I move the fader to deck B I can't hear anything, and only one of the volume controls works, and that is for A deck, and it works for both A and B deck.
I am a total noob, so please understand if this is a total noobish problem, thanks.
geposted Sat 09 Feb 13 @ 7:21 am
Make sure both Midilogs are set to USB (front switchers). Then launch VirtualDJ.
If the LE version has any Sound Setup in the Config have that as ,.
Inputs None
Outputs ..External Mixer
Sound Card .ASIO (AA ASIO) or AA VMS
Inputs None
geposted Sat 09 Feb 13 @ 10:06 am
and if there is no sound setup avaliable, please check the external asio panel. it should be set : deck1 = out1&2.....deck2 = out3&4
greetz
rob
greetz
rob
geposted Mon 11 Feb 13 @ 12:39 pm
