Yeah I see that now, looks like the VDJ Wiki isn't updated.
Regarding my "dark" 2900, is it a "midi CH" issue? What should the midi channels be set to on each SC2900?
geposted Fri 10 May 13 @ 9:46 am
From what phantomdeejay was saying recently, it shouldn't matter.
Apparently as long as each device has its own USB port, the MIDI channels don't clash.
geposted Fri 10 May 13 @ 10:03 am
well *something* isn't right, just trying to guess what is up with the "dark" 2900.
Currently have each 2900 and the 1600 in its own USB port (and I did try moving units to different ports).
I was planning to get a powered USB hub soon though....if/when I do that will the Midi Channel setting matter?
geposted Fri 10 May 13 @ 11:07 am
I asked earlier....has the dark one got the same firmware as the er, light one?
geposted Fri 10 May 13 @ 12:06 pm
Yes, first thing I did was update the firmware on both to current.
geposted Fri 10 May 13 @ 12:07 pm
I decided I had to make a run home @ lunch break ;)
Mixer/soundcard works after I made the necessary changes.
AND
set the naughty \"dark\" 2900 #2 back to the (default) midi channel 1...presto, no longer \"dark\"! So the midi channel does matter...begs the question how it will/won\'t work using a powered USB hub....
But for now...it seems like I\'ve got my new kit up and running! Awesome.
AND
geposted Fri 10 May 13 @ 12:54 pm
geposted Sun 12 May 13 @ 2:12 pm
Yes the MIDI channel does matter. When a unit is set to wrong CH number VDJ won't be able to send any MIDI out commands (and thus turn on leds, update screens, e.t.c.)
Also, I own a pair of DN-S3700 and they work great out of a powered USB hub ;)
geposted Mon 13 May 13 @ 12:08 am
Please use ASIO v2.22 with the SC2900/SC3900 decks found here:
http://usa.d-mpro.com/DocumentMaster/US/SetupASIODriver222.zip
geposted Tue 14 May 13 @ 2:44 pm
Yeah, initial testing with a USB2 Powered Hub have been successful.
geposted Tue 14 May 13 @ 3:19 pm
I've been using my 3900s through a hub since I got them without issue.
geposted Tue 14 May 13 @ 7:54 pm
Is there a setting somewhere that turns off/on the LED platter rings on the SC2900's?
Because all of a sudden they don't light up! :(
They do light up properly when switched to CD/USB though.
geposted Sat 18 May 13 @ 2:10 pm
Perhaps the issue is this last firmware update (v1100)? I'm pretty sure that the LED platter lights quit working in VDJ after I updated. Can anyone here confirm?
geposted Mon 20 May 13 @ 10:43 pm
Same Problem here. "jogs" are off.
Need some help to figure out ....
geposted Sat 29 Jun 13 @ 7:16 am
meanwhile:
Everything fine. And the mapping of the sc2900 is one of the best imo. LED-Support is great.
Thanks to the Dev-Team.
geposted Sat 21 Dec 13 @ 1:45 pm
