does the LPD8 connect simultaneously and act as the sampler controller on vdj?
id like to use for as a sampler for drops.
geposted Fri 15 Feb 13 @ 4:30 pm
Yes!
https://virtualdj.com/addons/controllers.html?category=best&order=default&search=lpd
But i believe you have to change the mapping in way you can use it.
means i have no idea how the mapping looks like, so you must tell VDJ what to do when you press the button x on LPD8 side.
geposted Tue 19 Feb 13 @ 8:07 am
thanks, ive got some learning yet on macs. been a pc guy my whole life.
geposted Wed 20 Feb 13 @ 5:23 pm
Is there any other way to get map the LPD 8 to just work with my samples only
geposted Tue 19 Mar 13 @ 5:37 pm
map the pads as something like
sampler 1 play_stop
sampler 2 play_stutter
sampler 3 loop on & sampler 3 play_stop
etc...
depending on what you need, then the knobs could control the different levels eg.
sampler 1 volume
sampler 2 volume
sampler 3 volume
etc...
the leds on the lpd are terrible, the only way I could get them to respond to the software output is to make them blink eg.
sampler 1 play ? blink 200ms : off
sampler 2 play ? blink 200ms : off
sampler 3 play ? blink 200ms : off
sampler 1 play_stop
etc...
sampler 1 volume
sampler 2 volume
sampler 3 volume
etc...
geposted Tue 19 Mar 13 @ 8:51 pm
