Is there an easier way to go back and clean up your recorded mix then recording it for a whole other hour just to fix one or two messy drops?
Thanks.
Thanks.
geposted Sat 16 Feb 13 @ 4:38 pm
Hi, Awkawe.
From within VDJ, I don't think so.
What you can do is record to an external program, like Audacity. Its free, and if you mess up a mix, or theres a power cut or something, simply re-record from the start of the track you messed up, and copy and paste the newly, properly mixed version onto the end.
Its almost cheating, but ten minutes of copy and paste is easier than re-recording the hour all over again...
Cheers,
Mike.
Cheers,
Mike.
geposted Sun 17 Feb 13 @ 8:36 am
word thanks
geposted Wed 20 Feb 13 @ 11:56 pm
