Hi,
Is it possible to link the BPMs across 2 or more decks?
Let's say I have deck 1 playing at 135 BPM, and I want to blend in a Drum & Bass tune at around 170 BPM on deck 2.
I can set the 170 BPM track to be the same BPM as deck 1 (135) and start mixing in the samples, but then I want to smoothly bring up the BPM on both decks to 170 BPM, with the BPM's remaining equal on both (so I only have to use one pitch slider).
Is there a simple way to do this on VDJ 7.3? I couldn't see anything obvious.
Thanks!
Thanks!
geposted Sun 17 Feb 13 @ 5:07 pm
Click the little lock next to the pitch sliders on the default 2 deck skin.
VDJScript verb is pitchlock - this will affect all decks though.
You could try using a VDJScript variable and switching the single deck pitch_slider out for multiple pitch_relative when set?
geposted Sun 17 Feb 13 @ 5:10 pm
Aha! I hadn't notice that. I've been using the the 4 deck skin for the last few months and it has no icon/button to do this via the user interface.
(This also means there is no way of knowing the current pitch slider lock status when using that skin. )
That's fine. Thank you!
I mapped the command to Caps Lock, whose button has an LED indicate when it's on.
But who would I need to speak to if I wanted to get this icon added to the default 4 deck skin? Or at least an indicator to show it's status?
geposted Mon 18 Feb 13 @ 4:39 pm
