Hello,
I'm sure this is somewhere in the archive of threads, however I'm very new to this forum so please forgive me if this has been covered but,
is there a way to instant double songs and to load songs without having to click and drag?
I use TTX turntables, American Audio DV2 mixer, Serato Time Code Vinyl and a laptop. With Torq I could hit F1 and F2 to load tracks on to decks, but I don't know how to do this on VDJ PRO. Do I have to map it to the keyboard of my laptop?
Thanks for the help
Thanks for the help
geposted Mon 18 Feb 13 @ 9:31 am
Not fully understand what you re after, but the scripts below should help you..
deck 1 load (loads the selected song to deck 1)
deck 2 load (loads the selected song to deck 2)
deck 1 load & deck 2 load (loads the same selected song to decks 1 and 2)
deck left clone_deck right (clones the left deck to the right)
deck right clone_deck left (the opposite)
You can assign them to keyboard shortcuts or to a midi controller (without using the deck x)
geposted Mon 18 Feb 13 @ 9:44 am
I want to be able to load tracks in VDJ PRO using the keyboard on my laptop and not click and drag to each deck.
If I have to map it to a particular key then I just need to know how to do that so I can just hit the key on the keyboard to load the deck.
geposted Mon 18 Feb 13 @ 12:19 pm
You can map 2 keys:
Key 1: deck 1 load
Key 2: deck 2 load
Key 1: deck 1 load
Key 2: deck 2 load
geposted Mon 18 Feb 13 @ 12:26 pm
Serato calls it Instant Doubles. In Virtual DJ, its called cloning a deck.
geposted Mon 18 Feb 13 @ 12:59 pm
Click on my name over to the left of the screen and it should take you to my page, then scroll down to the blog section. In there you'll find a video made that shows you how to map a controller or your keyboard.
Holla if you need more help....
geposted Mon 18 Feb 13 @ 1:10 pm
Awesome man thanks for that it helped a lot. BTW, how can I get a copy of that skin you used in the video??
geposted Tue 19 Feb 13 @ 8:08 am
