Hey I was looking to get a new mic, right now I'm using a $20 Samson I got from Best Buy its ok but it seems like I need to hold it close to my mouth when I speak. Wanted to know if you guys have any recommendations on a nice one don't want to spend more than $100. I will use it with my DDJ-SX it has XLR and 1/4 inputs. Also what about a USB mic so I can add effects to my voice. Thanks
geposted Mon 18 Feb 13 @ 10:27 pm
I would suggest going to a guitar center and trying out the Sennheiser E835 or the Shure SM58. They are both 99 bux and are both great mics. Let your ears decide. I prefer the sennheiser over the shure. The sound is not as flat and has a better low end.
As for a usb mic there is really only one good choice and thats the Snowball from Blue.
geposted Tue 19 Feb 13 @ 12:56 am
Will check those out thanks
geposted Tue 19 Feb 13 @ 1:20 am
The Shure SM58 is one of the favourits of many mobile dj`s....
greetz
rob
greetz
rob
geposted Tue 19 Feb 13 @ 1:23 am
greetz
rob
greetz
rob
Its a favorite among lots of Pro Audio folks. Mainly because the SM58 is virtually indestructible. It was made for the military. You can put a nail through the diaphragm and it will still work.
I just mainly dont like the sound of it when compared to the E835. Too flat sounding as if there is no life, not to mention I have to be too close to the mic to get my preferred volume out of the SM58.
geposted Tue 19 Feb 13 @ 3:25 pm
its a bit more money but the beta 87c is the answer to the flat sounding 58 also you should check out the beta 58a
geposted Tue 19 Feb 13 @ 3:35 pm
True the betas are better sounding, however the 87 is an condenser and I havent seen many mixers or controllers for that matter that have phantom power. The beta 58 is pretty good, however I think in a DJ environment you would be battling feedback more often based on the pickup pattern (Wide cardioid if my memory serves me right)
I used to be a pro audio guy and have setup sound systems and mixed live shows NUMEROUS times.
geposted Tue 19 Feb 13 @ 3:41 pm
The Shure 58 is an industry standard dating back decades. Cyder turned me onto some video on YouTube of the 58 being brutalized and, still working like a champ. The price for a 58 has been around $100.00US for twenty years. Really can't go wrong with it....
geposted Tue 19 Feb 13 @ 5:45 pm
