I just bought Virtual DJ PRO and would like to get started with using video with Virtual DJ.
Can anyone please help me get started with this as I have never done this before with Virtual DJ.
Thanks for any help you can give me.
Scott
Scott
geposted Tue 19 Feb 13 @ 7:17 am
First thing to do is register your serial number (under the My Account tab) so that you can download any updates, plugins etc.
Second, you'll need to be more specific about what help you need...
geposted Tue 19 Feb 13 @ 9:58 am
Ok rip all your Video to MP4 Then Enabled your videos ck activate to send your Video to the monitor and set up you folders for video and play with link with music or fader. when you ready to do pic for a side show the open side show folder then look for your pic on your CP hit the 1st Pic then close hit activate to show your pic on the monitor,if you need more have get the right info to get support/help and they will walk you.
https://virtualdj.com/products/virtualdj/
geposted Tue 19 Feb 13 @ 1:29 pm
@scomeau1
Video is working only in PRO, please register your lcense.
You dont need to convert any videos to MP4, because Virtual DJ supporting allmost all video formats.
Regards Tomas
Regards Tomas
geposted Tue 19 Feb 13 @ 1:39 pm
Is it possible to make up a continuous play list? I mean.... so that i can put tracks on both decks and they play automatically one after the other?
Thanks
Thanks
geposted Wed 20 Feb 13 @ 9:50 am
May I be the first to congratulate you on an excellent piece of thread hijacking. And I see you've cross posted too. Outstanding!
geposted Wed 20 Feb 13 @ 2:02 pm
yes , you can do everything you want on it.. video list and saved play list you need to down load the manual and google youtube..
geposted Thu 21 Feb 13 @ 1:23 pm
