Hello All
I'm interested in getting timecoded vinyls to work with my setup
VDJ 7 with M-Audio Conectiv soundcard.
All works perfectly with the timecoded cd's in my CDJ's but I have M-Audio Torq timecoded vinyls that don't work at all with VDJ 7.
What will work so that I can go back to vinyl mode.......getting bored mixing on CDJ's
Thank you
Thank you
geposted Tue 19 Feb 13 @ 4:33 pm
Please see our FAQ pages:
https://virtualdj.com/wiki/Timecode%20Requirements.html
geposted Wed 20 Feb 13 @ 12:08 pm
Did you purchase VDJ PRO ? otherwise you won't be able to use this function.
What is your set up? Are you trying to use analog turntables? If so what kind do you have.
The Connectiv box set up has to be done correctly for the signal to register.
geposted Fri 22 Feb 13 @ 10:10 am
