Hey all,
I did my first VDJ radio gig yesterday and I need to sort out a problem.
When I was broadcasting, VDJ itself was running slowly (the sound wasn't quite right and the turntable animation wasn't smooth).
I am running a 2010 Macbook Pro and a mixtrack pro, are there any settings I need to fiddle with?
Cheers,
Keep Kalm
Cheers,
Keep Kalm
geposted Mon 25 Feb 13 @ 7:49 am
Is it only running slow when broadcasting? Or all the time?
geposted Mon 25 Feb 13 @ 9:16 am
Maybe check the CPU usage when VDJ is running :)
geposted Mon 25 Feb 13 @ 11:08 pm
Are you using WiFi?
Are you connected to the chat room with the same computer you are mixing with?
geposted Tue 26 Feb 13 @ 9:10 am
Ctlr/alt/delete how many processes are you running? Right mouse button click on VDJ, select high priority. Turn off programs not needed.
geposted Tue 26 Feb 13 @ 9:48 am
Have you checked the FAQ?
MAC Performance issues:
https://virtualdj.com/wiki/Common%20Mac%20Performance%20Issues.html
geposted Tue 26 Feb 13 @ 10:05 am
Hoody, hit me up with a PM when you have time, we can connect to the test server and run through some things.
geposted Tue 26 Feb 13 @ 10:13 am
Has MBP got ctlr/alt/delete? ??
geposted Tue 26 Feb 13 @ 4:33 pm
Sorry for the late reply, I have been flat out.
It only runs slow when I am broadcasting, just mixing normally it is all good.
I am connected using an ethernet cable to my router and I use the same computer to mix and chat.
I will have a look in the FAQ to see if there is anything I can check
geposted Sun 03 Mar 13 @ 11:16 pm
