.i'm trying to use vocals+ to make acapella or instrumental samples but whenever i record the sample doesn't retain the effect and just plays the song as if no effects were used. is there anyway to fix this?
geposted Wed 27 Feb 13 @ 2:24 am
I have this problem too , I have AA vms2.
geposted Sun 08 Sep 13 @ 2:51 am
VDJ is DJ software. It's not designed to edit audio.
If you need to work with audio, use audio editing software such as Adobe Audition or Steinberg Wavelab.
geposted Sun 08 Sep 13 @ 5:00 am
VDJ doesn't apply effects to the recorded samples at this time, hopefully in the future this is added.
geposted Mon 09 Sep 13 @ 9:41 am
I guess at a pinch you could use the main VDJ record function, then load the result to a sample slot.
geposted Mon 09 Sep 13 @ 10:13 am
the other answer is that vdj takes the samples from the source file not the output from vdj. It actually has a great purpose of being able to record a sample and being able to play it immediately without needing to hear it first.
geposted Mon 09 Sep 13 @ 10:56 am
