Forum: Old versions
Topic: Pioneer Ddj-WeGo CD PROBLEM - Page: 1
I just bought a Pioneer DDJ-WEGO and mi computer doesnt have CD SLOT, so how can i download the software or what should i do??? ... P:S: Sorry for my bad english lol.
geposted Thu 28 Feb 13 @ 12:48 pm
I am having the same problem. But when I enter the serial number I only have the extension to download it for Windows, not for MAC. Does anybody know how to do it?
Thank you
hola amigos, mi cd de instalacion del controlador DDJ-WEGO DJ CONTROLLER se me quebro y tuve que formatear el pc donde tenia instalado el programa, el tema es que pude descargar el programa de la pagina, es el mismo, pero tengo un solo problema, los botones CUE con los signos de audifonos no me funcionan, prenden la luz pero no hacen su trabajo....tengo que activar algo? esta es la base para poder realizar buenas mesclas y no puedo :( ayudaaa HEEEELP!!!
Hi I had an account virtual dj but I forgot the name and password and I created another account but the problem that I have to download the virtuall dj (ddj-WEGO) but I can not because the serial and already as registered on the old
Hi All,
I purchased the Pioneer WEGO and installed the software on my laptop. I am now in Thailand and my laptop died so I have a new one but I do not have the software disc with me. Is there anyway I can download the LE version to install on my new laptop and work with my WEGO?
I need the software only.
Also if i purchase the PRO version of virtual DJ does the Pioneer WEGO work with this version
Thanks
i have a similar problem, i bought a second hand wego without cd and with the serial used by old owner. how can i use it without buying a new licence that would cost more than the controller i just bought ??
please help my virtualdj8 is not opening in my pc.nothings happened when i click the application.
Will my original CD was gone, my computer does not care to wash Software how should I do??
i just the Ddj -Wego but the software cd was broken
how can i get another one
You don't need a CD. Just install VDJ 8 and buy a license.
I formatted my notebook and tape recorder / CD / DVD player is not working and so do not have to install more software of my PARENT DDJWEGO and VIRTUAL DJ LE I bought along with the installation CD. I tried to do the procedure here on the site, even logged into my account, I fill the serial number that came in the parent company (referring to DJ LE) more say on the website that the number is already registered. What I do?
Please contact support and provide the serial (keygen) of your VirtualDJ LE
hi,i lost my cd of software for my limited edition ddj-wego and now i cant play.what i can do because i only have free home edition.can help me
i have a ddj wego but i dont have cd nd any serial no so how can i use in my laptop our ant software send me the link
95%
