Does anyone know if there is an easy way to take the song list that is in VDJ and print it out. For example I have a file that all my Karaoke files are in that I play through VDJ? I want to print our a list of them so people can see what I have and request a song.
geposted Thu 28 Feb 13 @ 10:18 pm
Hmmm, was wondering the same question.
geposted Thu 27 Mar 14 @ 3:52 pm
dir *.* /e/s >songlist.txt
or try
http://www.karaosoft.com/Products.aspx
Their Songlist Generator
or try
geposted Thu 27 Mar 14 @ 3:58 pm
Create a filter folder with:
type=karaoke
select the filter folder, now you should see all your karaoke files in the browser.
Create a playlist with all these files, save the playlist.
Go to your VirtualDJ/Playlist folder on C: drive.
Open your playlist with notepad.
Print that file.
type=karaoke
Print that file.
geposted Fri 28 Mar 14 @ 5:26 am
formatted printing of a playlist would be a great feature to add.
I actually just started using vdj more now that i'm offering karaoke and it's great for searching for and playing requests.
But yeah about printing playlists, I was just ctrl-clicking on the playlist names and there is load, merge, etc. I was expecting to see a print and export.
It also would be nice to be able to select which columns are printed for example artist, title, maybe that's all you want or maybe you want song location. Maybe you want to export a playlist to CSV format for importing to some other system, that would be great also.
Actually better yet right in the playlist menu - the one that has start automix, etc. would be a good place to put the print/export based on what columns are being displayed.
geposted Mon 28 Apr 14 @ 3:25 pm
I just realized we can drag the .m3u playlist file onto iTunes and print whatever from there.
geposted Mon 28 Apr 14 @ 9:03 pm
Or try that one.
https://virtualdj.com/addons/13213/DJF_Playlist.html
geposted Tue 29 Apr 14 @ 3:08 am
