i have a numark N4 and have a problem with the left sync botton on the controller, if i press the sync botton on my numark n4, virtuel dj sync botton, react to it, but do nothing about it, no matter if there are 1 bpm or 20 between the two songs. my right siync botton on the controller works everytime no matter what.
what could be the problem?
geposted Fri 01 Mar 13 @ 2:29 am
You need to set the MASTER to which it should sync before. This is when you are using a skin with more than 2 decks. Mostly there is a button ot text saying MASTER you can click to.
In my default skin is a text above the sync buttons.
Greets, Heiko
Greets, Heiko
geposted Fri 01 Mar 13 @ 2:31 am
