Ok so I have a different controller i have the numark mixtrack pro instead of the mixtrack. but when I try to use virtual dj with the mixtrack pro it isn't working. my mixtrack pro came with serato but i would rather use the virtual dj any help?
geposted Fri 01 Mar 13 @ 1:32 pm
i had the mixtrack and now i have the mixtrack pro so two different controllers but the same program doesn't work.
also I have virtual dj le and I was using the trial virsion but I accedently deleted the trial virsion when I had 8 days left....is there any way I could retreve those 8 days?
geposted Fri 01 Mar 13 @ 1:34 pm
VirtualDJ LE is free limited software and will only work with the type of controller it was included with. VirtualDJ LE for MixTrack will not work with MixTrack Pro. You will need to upgrade to the full VirtualDJ Professional at a discount to use this or any other controller: https://virtualdj.com/buy/
If your Pro trial has ended or expired then your only option is to use Home FREE for 10 minutes at a time if you wish to continue testing Pro features. Please see https://virtualdj.com/wiki/My%20trial%20has%20expired%20early.html
geposted Fri 01 Mar 13 @ 1:53 pm
