I have VDJ Pro7 loaded onto 2 laptops. If I download a track from netsearch and save it to my cache on one computer will it show on the other as well?
geposted Sun 03 Mar 13 @ 4:51 pm
No, it will only show on the PC it has been downloaded to.
Keith
Keith
geposted Sun 03 Mar 13 @ 5:08 pm
Thanks......So I'm about to get rid of these two laptops and get another one. Will I have to download my cached files again or will they transfer to the new computer?
geposted Sun 03 Mar 13 @ 5:29 pm
I think you have to transfer the files to your new computer.....
geposted Sun 03 Mar 13 @ 9:13 pm
if you take your cached files and put them in a cloud list, you can easily redownload them. i think this is one of the points of having the cloud list feature
geposted Mon 04 Mar 13 @ 9:18 am
You can simply copy the cached files across from Documents\VirtualDJ\Cache on the old computer to the same folder on the new one. This will save you having to download them all again.
Please also see https://virtualdj.com/wiki/How%20do%20I%20transfer%20the%20software%20from%20my%20old%20computer%20to%20my%20new%20computer.html
geposted Mon 04 Mar 13 @ 9:34 am
