well after a long break from playing music i got the old turntables out and started playing again , the problem i have is even on low volume the bass travels straight thru the floor to the room below , i dont want to just remove the bass from my music as it sounds awfull is their anything thats any good to lower the bass , at the moment i just have my m-audio bx8's on stands .
geposted Mon 04 Mar 13 @ 6:59 am
Have you looked into something along these lines? -> http://www.pssl.com/Auralex-MOPAD-4x-Studio-Monitor-Issolation-Pads-
geposted Mon 04 Mar 13 @ 7:01 am
i have seen some like those but i didnt know if they would actually help or not .
geposted Mon 04 Mar 13 @ 7:37 am
The simplest thing is to get the speakers off the floor. Stands or as suggested isolating pads all good ideas. You could also look at using a smaller pair of "Bookshelf" hifi speakers or small monitors to try and reduce the amount of bass vibration but still keep most of the sound you want.
Good luck
Daz
Good luck
Daz
geposted Mon 04 Mar 13 @ 7:45 am
These are amazing for £39.00
More than enough if you're just mucking around at home.
http://www.richersounds.com/product/bookshelf-speakers/wharfedale/diamond-9.0/whar-9.0-blk
Keith
Keith
geposted Mon 04 Mar 13 @ 8:47 am
Go to a dollar store and buy 4 rubber balls. Cut them each in half and place each speaker on 4 of the halves.
I played a club where I took in my Acoustic double 18 bin and had it on the floor. When kicking it... downstairs in the basement bar there was a very annoying buzzing sound from the vibrations.
I put the bass bin on the 4 half balls and no more noise. It was very cheap and worked well.
geposted Mon 04 Mar 13 @ 6:33 pm
