Hello,
I have several DJ Name intros and drops by Wigman, but I have no idea how to load them into the effects or sampler section of VDJ Pro Full. Help?
geposted Tue 05 Mar 13 @ 8:01 pm
1. If you click on SAMPLER there is a circle right underneath of the play button in the bank on the top right corner.
2. Then you click that circle and click on LOAD.
3. You then search where you saved them click on the drop that you want then click on OPEN they should be added
Repeat steps till you have them all loaded to the banks.
Good Luck
Charlie
Good Luck
Charlie
geposted Tue 05 Mar 13 @ 8:18 pm
Ah thanks I got it!
geposted Tue 05 Mar 13 @ 8:28 pm
You should try commercialkings.com/djdrops for your next dj drops. their stuff is super hot!!
geposted Tue 28 Oct 14 @ 9:32 pm
You dug up an 18 month old post?
LOCKED
LOCKED
geposted Wed 29 Oct 14 @ 7:03 am
