EDIT, now it's working for some reason. I dunno....
Still, I'd like to press a key and "stutter" when pressed too. Possible?
Original (old) post:
I setup a "dump" key (for each deck) on my keyboard to play backwards while pressed - while keeping the time going. So when you let off the key, normal time elapsed. Now it's not working. Here's my actions:
deck 1 dump while_pressed (mapped to keyboard key "D")
deck 2 dump while_pressed (mapped to keyboard key "L")
1) What's the proper syntax to get this feature working again?
2) I've heard from another used that I can get this same functionality with a single key. That would be ideal. How can I used one key for either deck - which ever one is playing on the floor?
3) I've also seen another DJ play a stutter effect to produce the same type of on-the-fly censorship. How can that be done?
I think it would be nice to have a single key mapped for each style of "bleeping". The backward spin is less obvious. And there's time where the stutter sounds pretty cool too.
How do you handle these needs via keyboard shortcuts? Thanks!
geposted Tue 12 Mar 13 @ 8:53 am
