Testing virtualdj on microsoft surface pro. So far so good. Biggest issue I found is scroll bars are too small to use finger. Can this be modified in the skin?
geposted Tue 12 Mar 13 @ 6:04 pm
No, this is not possible at the moment.
Hopefully a proper touch support will be added (scrolling) in a future release. You may ask for that in our Wishes Forums.
For now, you can use skins made for touchscreens, that have some navigation browser buttons.
geposted Tue 12 Mar 13 @ 6:28 pm
Damn. Know of any mouse emulating programs or a way to fast scroll with the jog wheels?
geposted Wed 13 Mar 13 @ 7:07 pm
Are you sure you can't change the thickness?? I could of swore this was in the browser elements somewhere. I know you can change the color......
geposted Thu 14 Mar 13 @ 1:23 pm
Huey, you can change the color but not the size (thickness)
Wireless...
Are you referring to the jogwheel of the skin ? This can not behave like the jogwheel of a controller with jogwheel_mode action
You can add some buttons in the skin to browser_scroll +20 like page down/up
Wireless...
geposted Thu 14 Mar 13 @ 2:33 pm
Yes, like shift plus jog wheel to fast scroll used to be possible on the vci300
I literally can not scroll with the touch screen unless I have a mouse
geposted Sun 17 Mar 13 @ 9:21 pm
