hey guys :)
i'm using Reloop TM2 DJ Controller
and i have 3 effects buttoms in deck a and deck b
so when i'm using FX 1 FX 2 and turn them on
i have 3 effects
1 - Beatgrid
2-Backspin
3- Brake
i want to change them who can i do it ?
even if i'm trying to put flanger or something it still going back to these to effects
i have 3 effects
1 - Beatgrid
2-Backspin
3- Brake
geposted Wed 13 Mar 13 @ 8:18 am
If you're using a LE version then you can't modify your mapper besides the 20 days trial of PRO. It will revert back to the factory settings.
geposted Wed 13 Mar 13 @ 8:29 am
I'm usting VDJ 7.3 Pro FULL
not LE Verison
not LE Verison
geposted Wed 13 Mar 13 @ 9:37 am
Please register your Pro serial number on your profile page https://virtualdj.com/users/edit.html and then download the latest version from the Download Center: https://virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: https://virtualdj.com/buy/ (Especially if you are working DJ and are making money as a result of using it at your gigs.) Your VIrtualDJ LE serial number should entitle you to a discount off the cost of upgrading (Providing that it's not second hand and has not already been used.)
Once you have done this, please see https://virtualdj.com/wiki/How%20do%20I%20change%20the%20mapping%20for%20a%20button.html
geposted Wed 13 Mar 13 @ 10:16 am
