I'm trying to locate drivers for my Ecler NUO4 and I'm not getting anywhere. I've email the company have yet to get a response (that was a month ago)
So does anyone know where I can download them or maybe email them to me?? I know Ecler is used overseas more then in the states so possibly someone could help me??
Thanks for the time
Huey
P.S. I bought the mixer used and didn't get anything but the mixer which is why I don't have them. I thought I had them but I can't seem to find the disk I burned.......
Thanks for the time
Huey
geposted Wed 13 Mar 13 @ 11:12 am
Not sure if this is what you're looking for.
http://www.eclerdjdivision.com/downloads.php?ap=6&sub=6&lang=
geposted Wed 13 Mar 13 @ 11:30 am
Doesn't seem to be specific drivers for it?
geposted Wed 13 Mar 13 @ 11:34 am
Yeah I've downloaded from that page, it's some software like the Korg editor, Thanks for looking though.
So you think it works with some sort of generic windows drivers then??
geposted Wed 13 Mar 13 @ 11:38 am
Looks like it may be plug & play.
Does a device appear in Control Panel> Sound when it's plugged in (or are you using a Mac)?
geposted Wed 13 Mar 13 @ 11:44 am
From what I can see on the Ecler web site, the NUO 4 is an analog standalone mixer - it doesn't need drivers, you can't connect it to a computer.
geposted Wed 13 Mar 13 @ 11:52 am
Keith I'll check when I get home.
Groovin, that's the NUO 4.0 mine is the NUO4.
The NUO 4.0 is the mixer they replaced the NUO4 with. Never fully understood why they stopped making them. It's MIDI, MIDI clock out, has send/return, 4 channels and the eq's are the best I've ever used. This mixer sounds so dam good on a loud system. The mixer has a ton of features for the scratch Dj as well as the house Dj. I love my Ecler!!
Oh and it's Traktor ready, lol!! I'm gonna mod one and put an Audio 10 into it........
P.S.
I found them, they were bundled with the software download!!
P.S.
geposted Wed 13 Mar 13 @ 11:57 am
That's some daft naming conventions, calling two different products by an almost identical name!
It's also pretty stupid of Ecler to remove the drivers from their web site (assuming they were there in the past).
EDIT: bundling them with the Control4Lab s/w is daft too. How is anyone supposed to know they're there? :-O
geposted Wed 13 Mar 13 @ 12:20 pm
Agreed, lol!!
My only complaint about the mixer is, when you switch channels 2&3 you loose the audio so basically in MIDI mode it's only a 2 channel mixer. Looking at the schematic we should be able to change that when were adding the Audio 10. Then I'll have audio on all 4 channels plus MIDI and I'll be able to use the last input/output for the send/return when using a software that supports it.
geposted Wed 13 Mar 13 @ 12:55 pm
