hello,
I have a problem as follows:
I bought me a mixtape per Numark 2, use it with virtual dj pro 7th
Now I have connected everything (did not chinch unfortunately not home system with 3.5 mm).
Now though I can use the controller but not the auditioning function works?
The sound comes out of the box and the headphones, I can not separate the sound eg music run on a deck on the same box and deck b hear in my headphones!
I despair, please help quickly
MFG :-)
MFG :-)
geposted Mon 18 Mar 13 @ 4:32 pm
Here is something that may help you with your issue https://virtualdj.com/wiki/Pre-listening%20with%20headphones.html
Good Luck
Good Luck
geposted Mon 18 Mar 13 @ 7:44 pm
