Hi I have just downloaded the free home version and opened it for the first time a second ago. Its only showing half of the decks, guessing its zoomed in and cant change it... any Help would me much appreciated. Im using a Sony Vaio F series. windows 7.
Thankyou
Paul
Thankyou
Paul
geposted Tue 19 Mar 13 @ 6:48 am
Try Ctrl+Alt+Del to bring up task manager
In the Applications tab right click Virtual DJ and select Maximize.
Hopefully that should shrink the resolution and then you can go to config > skins and select a resolution to fit your screen.
Keith
Keith
geposted Tue 19 Mar 13 @ 6:50 am
Thankyou!!!!!!!!!!!!!!!!!!
geposted Tue 19 Mar 13 @ 6:53 am
No problem, let me know if you require any further information or help.
Regards
Keith
Regards
Keith
geposted Tue 19 Mar 13 @ 6:58 am
