Virtual DJ Pro 7.3 ?s ::
I bought VDJ Pro 7 & have been using for a few years. I am using with my brand new Vestax VCI-400 & running into some issues. I use Macbook Pro with 10.6.8. I installed the updated VCI-400 firmware (2x), restarted.
Configuration...
Inputs: None
Outputs: External Mixer - Deck 1 Channel 1 & 2 / Deck 2 Channel 3 & 4
SoundCard: 4 out card / VCI-400
Question:
-Deck 2 is triggering when I hit Play button, can set Cue, but cannot hear audio when I put up channel volume faders up on Right side 2 channels, tried everything (trim, mute,...). Please help. I have gig in few days & need to get this thing fully functioning with VDJ!
Serato DJ Intro ?s ::
I have just bought the Vestax VCI-400. I have some ?s that I am baffled by.
I am using it on MacBook Pro with 10.6.8. Its is a brand new Vestax VCI-400.
I installed the updated VCI-400 firmware (2x), restarted, installed Serato DJ Intro just yesterday (1.1.1) & Serato VCI-400 firmware update. First it wasn't recognizing hardware. Now it does &
cue & play button not working, everything else working fine.
Please help me get the Cue & Play buttons working then I can use for gig tomorrow!
ALSO....the power adapter this came with is complete garbage! Two cheap plastic compenents that fit together very very poorly
& come off & lose power during your performance! Not cool!
Just want to get VCI-400 working properly on one of the two above softwares for gigs coming up!
Any help appreciated!!
geposted Tue 19 Mar 13 @ 11:55 am
