I just re-uploaded the device and mapper files and can confirm that they are working on the Launchpad S
geposted Wed 26 Mar 14 @ 8:53 am
Thank You, I try them again
geposted Wed 26 Mar 14 @ 2:48 pm
IT WORKS!!!
ITS AMAZING!!!
May be I had different def-files at the same time?
However: I deleted the others and reinstalled Your amazing Plugin and now I´m HAPPY
THANK YOU!!!
ITS AMAZING!!!
THANK YOU!!!
geposted Wed 26 Mar 14 @ 2:58 pm
I'm happy to hear you got it working. You really had me scratching my head for a bit :)
Have fun with it!
Have fun with it!
geposted Wed 26 Mar 14 @ 3:03 pm
great jobs guys!
geposted Wed 26 Mar 14 @ 10:46 pm
I purchased the license for virtual dj and novation launchpad. But there iix a notification that says that my licenses aren't allowed to download this????
geposted Fri 29 Aug 14 @ 3:59 am
If you've bought a "controller license" for VDJ 8 then it will only allow you to use VDJ with that one controller.
Downloading mappings is not permitted because that would allow you to use other controllers.
geposted Fri 29 Aug 14 @ 4:05 am
So the purchase is wasted money? Sad -_-
geposted Fri 29 Aug 14 @ 4:09 am
No - if you paid for a license to use VDJ 8 with the Launchpad, that's what you've got. The mapping is built in.
geposted Fri 29 Aug 14 @ 4:15 am
hey guys ,
does this mapper work wit VDJ8 ? It said its installed but i dont see it in mapper list
geposted Thu 25 Dec 14 @ 2:54 am
HELP PLEASE
Does this work on VDJ8? My copy is detecting it, but it's a totally different mapping, which I'm assuming is the VDJ8 stock mapping. How do I specifically use this mapper with VDJ8?
geposted Fri 16 Jan 15 @ 8:25 pm
You can add force- to the mapper name to ensure VDJ 8 uses it instead of the native mapping.
So if it's called Launchpad OPD Mapping.xml change it to force-Launchpad OPD Mapping.xml
geposted Sat 17 Jan 15 @ 6:42 am
