Topic: DDJ-SX not properly working with 7.4 - Page: 2
Describe please step by step what you did. Include fw nr.
Pioneer ddj sx Manufactured February 2013
DDJ-SX driver ver. 1.000
DDJ-SX firmware 1.05
Latest mapping by PhantomDJ
When I use advanced configuration in audio set up, both decks play but the sound is distorted
When I use output external mixer Deck1: Chan 1&2\ Deck2: Chan 3&4
Both decks seems to be playing but only sound from the left deck plays in the speakers. Headphone is also having no sound.
I also delete the LE and Pro versions with all their files and made a fresh reinstallation but still no success.
You should use SIMPLE (Not Advanced) audio setup:
Inputs: None
Outputs: Headphones
Soundcard: Pioneer ASIO
Sound setup should be:
Input: None
Outputs: Headphones
Sound card. ASIO
Thats all
Regards Tomas.
Hah George was faster :-)
Wow it works great now. Thank you PhantomDJ and Tjeck1972 and I wish you all a nice Easter Holidays.
Tjeck1972 wrote :
FX knobs issue is not corrected in this native ver. Now is only PhantomDJ´s mapper working as it should.
FX knobs work as intended in single mode in the native mapping.
The order (Left-to-right) is: FX select, FX param 1, FX param 2, beat jump (Knob is labelled 'Beats')
The buttons (Left-to-right): FX active, FX button 1, FX button 2, beat tap
With SHIFT, they control video FX, video FX param, video transition.
You can also press SHIFT+TAP to enter multi-FX mode. Each of the three FX knobs then controls an individual effect and its parameter. SHIFT+knob controls parameter #2 and SHIFT+button selects which effect is assigned (Use a skin with effect slots to see which is selected.)
NOTE: If you prefer Phantom's mapper layout, you can use it instead if you wish or you can even customise the DDJ-SX to suit your own personal preferences.
Thank you for reply. But only Knob labelled 'Beats' has nudge´s, and that is ( what i think) very usefull only for "select" mode.
Regards Tomas.
