So I love this skin! I use to make my old skin change the center Mixer & Video panels using the source selectors on my NSFX. It has A, B, Aux, Main switch. I set aux to my Video mixer panels and the others to Mixer.
The problem here is that the center mixer panels change with 2 or 4 deck mode. When I set it up to use 2 decks, my mappings were calling up the 4 deck panels. So my cross fader would show up in the browser. So I want to make a mapping question like this:
var "deck_mode" ? skin_panel "video" on : skin_panel "video2" on
The problem here is the skin commands. I actually crash the skin editor when I highlight that section of code. I need to make multiple commands on these two lines:
<button panel="4db" action="skin_panel '2decks' on" & 'set "deck_mode" 0'>
<button panel="2db" action="skin_panel '4decks' on" & 'set "deck_mode" 1'>
But these mods are obviously wrong when they completely force close the skin editor. The idea is to ask something in my mapper so that it knows if I am in 2 or 4 deck mode, so that it chooses the right 2 or 4 deck mixer panels in the map.
Thanks in advance for any help you can give!
geposted Sat 23 Mar 13 @ 3:05 pm
Some progress, not sure where the fault is yet but the skin commands don't crash the skin editor tool and the modded skin loads now with these:
<button panel="4db" action="skin_panel '2decks' on & set 'deck_mode' 0">
<button panel="2db" action="skin_panel '4decks' on & set 'deck_mode' 1">
Button mapper for Aux is set to this:
var "deck_mode" ? skin_panel "video" on & action_deck 1 ? set "modeA" 3 : set "modeB" 3 : skin_panel "video2" on & action_deck 1 ? set "modeA" 3 : set "modeB" 3
In 2 or 4 deck mode, it only seems to default to the 2 deck mixer. So it must see a "True" (not zero response). I have to be close, any help you can give is much appreciated!
geposted Sun 24 Mar 13 @ 3:48 pm
hola como puedo descargar eskin de esta pagina alguien puede ayúdame
geposted Wed 27 Mar 13 @ 8:54 am
Sorry, this forum is for English language messages only.
Please either post your message again in English or use the appropriate language forum at the bottom of https://virtualdj.com/forums to post in your own language.
Skins are also only available to registered licensed users who have purchased VirtualDJ: https://virtualdj.com/products/comparison.html - Do not ask users to send you add-ons to which you are not currently entitled or your account will be locked.
geposted Wed 27 Mar 13 @ 10:54 am
Dont edit the skin. There is no need to add any variable to toggle between the panels. All u need to query is the panel that is on each time.
Example.
One button to cycle through all the Mixer panels depending on 2 or 4 decks view...
skin_panel '2decks' on ? skin_panel 'mixer2' on ? skin_panel 'video2' on : skin_panel 'video2' on ? skin_panel 'scratch2' on : skin_panel 'mixer2' on : skin_panel 'mixer' on ? skin_panel 'video' on : skin_panel 'video' on ? skin_panel 'scratch' on : skin_panel 'mixer' on
One button to cycle through Mixer & Video panels depending on 2 or 4 decks view...
skin_panel '2decks' on ? skin_panel 'mixer2' on ? skin_panel 'video2' on : skin_panel 'mixer2' on : skin_panel 'mixer' on ? skin_panel 'video' on : skin_panel 'mixer' on
Example.
geposted Wed 27 Mar 13 @ 4:18 pm
