I was messing around with the mapper of my DN-S3700 and I changed almost half the display mapping:
The video is just a teaser, I created it mostly to showcase the usage of my "Skin Companion" plug-in, but that's another story ;)
It's from my Smartphone, but it's in HD so that you should be able to tell what's happening and what's different... :)
geposted Tue 26 Mar 13 @ 3:42 am
Finally I completed my 100% custom made mapper for the DN-S3700!!!
Here's a video of the display (again)
1) The Track Nr shows the active cue instead of the deck number
2) I activated the hotcue points indicators (the red dots under the progress bar). The active cue-point will blink, and when the deck is in loop both loop-in and loop-out points will show up and blink. I may change the blink refresh rates though...
3) I modified the scratch disc so that it can also be used as a bar. On the video it shows the FX Slider position when an effect is activated (it behaves similar with the native CD display mode)
The video has been taken by my cell phone, so it's not of the best quality, but you should get the picture!
I will try to take my Camera with me next time and shot a proper video of the entire mapper!
Thanks!!!
geposted Mon 13 May 13 @ 3:20 am
