I am having an unusual problem. After about 20-25 minutes into my set, my songs on the right deck starts playing at a slower speed than the left deck. I can have the same song, with the same BPM but one side moves significantly faster/slower than the other side.
I have deleted and re-installed my VDJ software about 5 times. BUt still continue to have this issue.
I also have smart tap disabled and auto-pitch match disabled.
This problem occurs even when my hardware isn't plugged - i.e. when I'm on just my laptop.
Has anyone faced a similar issue????
geposted Fri 29 Mar 13 @ 5:40 am
What hardware/sound card/midi controller are you using ?
What is your Sound Setup in CONFIG->Sound Setup tab ?
Please also post 2 screenshots , if possible...
1. From Sound Setup of VirtualDJ
2. From Audio Midi Setup (Applications-->Ulitities)
geposted Fri 29 Mar 13 @ 9:29 am
I also had the same thing on my mbp No matter what even sync One of the the songs was allways faster, using the normal settings and the mbp does not connected to anything. It stopped after a few restarts But it is very disturbing...
Never happened to me on my pc.
geposted Mon 01 Apr 13 @ 7:34 pm
