Hi,
I'm having a problem with Virtual DJ Pro. When the 3 EQs (Treble, Mid and Bass) are set on to default (0) and I turn anyone of the 3 ever so slightly when the track is playing, it's always making a clipping noise.
It's been almost a month that I'm using the Mixtrack Pro with Virtual DJ, without any problem. But it started suddenly, without any changes on my part.
I'm positive the Mixtrack Pro is not the problem, as it's working fine with Traktor. This means it's a problem with Virtual DJ. Also, everything is working fine when I put any one of the 3 EQs slightly off. For instance, if I put the MID slightly above, I can use the Treble and Bass without any clicking noise.
Any help on this? It's driving me mad... :(
Thanks
Thanks
geposted Tue 02 Apr 13 @ 10:22 am
Hi,
here you can see the settings.
https://virtualdj.com/wiki/MixTrack%20Pro.html
Please use the latest Pro Full version from our side.
To safe you get the latest version, please register your licence key under your account.
https://virtualdj.com/users/edit.html
Only that way you will be able to download our latest version here:
https://virtualdj.com/download/updates.html
geposted Thu 04 Apr 13 @ 3:09 am
