Please can one of the virtual dj skinners possible make a skin for the voxoa C60.
Replace those with 1200s and that my set-up
geposted Wed 03 Apr 13 @ 7:44 pm
Create a skin is a long work (weeks / months) ! I doubt anyone have as much time to spend just for you.
The best thing is to make yourself, this is not difficult.
geposted Wed 03 Apr 13 @ 8:35 pm
The Voxoa C60 has a lot of simirarities with the Stanton DJC4. So the best option for now is, either to use this skin or modify it, in case there are some minor differencies.
https://virtualdj.com/addons/15655/Stanton_DJC-4_.html
geposted Fri 05 Apr 13 @ 11:43 am
ok when at my resolution that skin is taking up most of the browser can i use it at 1024x768 even when my native resolution is 1366x768 with out it being a problem like using a higher resolution.
geposted Fri 05 Apr 13 @ 6:47 pm
