Topic: Virtual DJ portable doesn't save my mappings
Hello all,
A bought a harddisk for my musiccollection and my virtual DJ so I can take it easily with me when I'm playing at a party. So I installed virtual DJ portable on it. But when I map my controller, the next time I open up Virtual DJ portable, my mappings are all set to the factory settings. What's the fault I make? I don't like it when I always have to map my controller;)
Greets
geposted Sun 07 Apr 13 @ 5:08 am
We do not sell any kind of portable App. This is in fact an illegal cracked version you are using !!!
Greets, Heiko
Thanks for your reply, I didn't knew I was using a cracked version. I've deleted it a few seconds ago.
Greets
Just to clear things up. A you referring to a version other than your LE version you have registered?
Cheers,
Roy
You will need to purchase the full VirtualDJ Professional to be able to use custom mappings, skins, etc. Your VirtualDJ LE should entitle you to a discount off the cost of upgrading: https://virtualdj.com/buy/
If you like VirtualDJ, please support the software and its future development by purchasing the full version: https://virtualdj.com/buy/ (Especially if you are working DJ and are making money as a result of using it at your gigs.)
