Forum: Old versions
Topic: DDJ-SX 7.4 with new SX Skin and Mapper
Hi guys,
Has anyone successfully upgraded to the new version and is using the new DJDad SX skin with it all working good.
Anyone gigged with it with no issues?
I am about to upgrade but just wanted to make sure as i broadcast and connot afford much downtime
Thanks guys
geposted Thu 11 Apr 13 @ 11:19 am
Upgrading to version 7.4 will provide much better jog response (and some LED issues fixes) , as the Sx will work on "Serato" mode and not in "Other software" (you ll have to switch your device to Serato MODE).
You will have to delete the SX files from \VirtualDJ\Devices and VirtualDJ\Mappers folders and install either the updated native mapper https://virtualdj.com/addons/15822/Pioneer_DDJ-SX_(Native).html or the updated Phantom's mapper https://virtualdj.com/addons/15383/Pioneer_DDJ-SX.html .
The SX skin follows 95% the default mapper.
DJdad,
Thanks so much for your response. Just one final question. I read somewhere in this forum that if i commence with the upgrade i will no longer be able to run the Serato DJ anytime i want. More like' it's an either or situation. Is this true? Can anyone pls confirm?
Thanks all
Installing VirtualDJ has no effect on Serato and vice-versa.
This comment may come from the fact that prior to the native support in VirtualDJ v7.4, you had to switch the DDJ-SX to 'other software' mode to use it with VirtualDJ. This is no-longer the case and you should leave it in the default Serato mode. It will work with both software in this mode, but obviously you can't run both simultaneously!
