I have a new HP laptop that I cannot get my old USB2 sound cards to work with. I tried a powered USB 2 hub, and they still wont work. They are generic sound cards, and I can't find manufacturer driver updates for them.
I am guessing that I need to buy a new USB sound card, and wondered if anyone has suggestions for something that will work with the newer USB3 connections. Using Windows 7, with i7 processor, and 8 gigs of ram. Any suggestions would be greatly appreciated.
geposted Fri 12 Apr 13 @ 10:11 am
What's your budget?
geposted Fri 12 Apr 13 @ 1:49 pm
$200.00
geposted Fri 12 Apr 13 @ 2:04 pm
esi audio. Gigaport HD. . 24/96. Low latency great sound
geposted Fri 12 Apr 13 @ 10:08 pm
Thanks for the suggestion!
geposted Sun 14 Apr 13 @ 1:14 pm
Has that been proven to work on a USB 3 connection?
As I understand it, failures of USB 2 devices to work from USB 3 sockets is more to do with the chip set in the computer than the audio interface itself.
geposted Sun 14 Apr 13 @ 5:56 pm
I can not say for sure if it is usb 3 compatible. I have usb 2 on my laptop I can say it is a fantastic sound card I have had the gigaport ag (older model) since 2002 when I first started dj'ing with a laptop. never a pop or crackle. I will email them and see if it works with usb 3
J
J
geposted Sun 14 Apr 13 @ 6:15 pm
I emailed and asked about usb 3 here is the reply
Dear John.
In our tests the Gigaport AG and Gigaport HD+ works with USB 3.0 ports.
Best Regards.
UK Support.
ESI Audiotechnik.
TEL: +44 (0) 1280 847525.
Dear John.
Best Regards.
UK Support.
ESI Audiotechnik.
geposted Mon 15 Apr 13 @ 1:50 pm
