Topic: djboggis controller mapper for DDJ-SX - pitch shift??
Is there a pitch shift +/- in the latest mapper? I DJ'd with it last night and couldn't find it. Please direct me in the correct direction.
Funkmasterfrank
geposted Sun 14 Apr 13 @ 8:15 am
If you mean pitch bend -/+, then no, this function is not present because the DDJ-SX doesn't have buttons for this function. However, you could map other buttons that you don't need to these functions if you wish, e.g: The < > PARAMETER1 buttons when in HOTCUE mode, or perhaps the GRID ADJUST and SLIDE buttons.
Simply map the buttons of your choice to:
pitch_bend -2% 500ms
pitch_bend +2% 500ms
If you meant key shift -/+, then map them to:
key_move -1
key_move +1
bump
Sorry are you saying key meaning pitch?
Forget the last 2 post = I made a mistake
Thank you, I'll try that
Please help...
I need the mappers for the the DDJ sx, I am using windows.. I have done everything it says to do on this site and it still isn't working...
Sorry, mappers are only available to and can only be used by registered licensed users who have purchased the full VirtualDJ Professional.
Please register your Pro serial number to your account https://virtualdj.com/users/edit.html and then download the latest version from the Download Center, which natively supports the DDJ-SX (No mapping is necessary): https://virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: https://virtualdj.com/buy/ (Especially if you are working DJ and are making money as a result of using it at your gigs.) You can upgrade from VirtualDJ LE to the full Pro at a discount.
NOTE: DO NOT ask users to send you mappers to which you are not currently entitled otherwise your account will be locked.
