My skin resoulution on laptop is at 1400x900 and i set my vdj screen @ the same , pushing 3.00 gb of ram also using the ns6 with all other apps closed including wi fi ect. and ti still freezes & pop HELP
geposted Sun 21 Apr 13 @ 10:10 am
Your computer needs optimized. Start here: https://virtualdj.com/wiki/Common%20PC%20Performance%20Issues.html
Keith
Keith
geposted Sun 21 Apr 13 @ 11:33 am
This is what the NS6 requires. If your laptop has less than this, Its Under specs.
Mac Mac OS X 10.6.8+ 32-bit: 1.8GHz Core Duo
64-bit: 2.4Ghz Core Duo 32-bit: 1GB
64-bit: 4GB 2.0
Windows Windows XP / Vista / Win7 32-bit: 1.8GHz Core 2 Duo
64-bit Vista: 2.2GHz Core 2 Duo
64-bit Win7: 2.4GHz Core 2 Duo 32-bit XP: 1GB
32-bit Vista / Win7: 2GB
64-bit: 4GB 2.0
64-bit: 4GB 2.0
64-bit: 4GB 2.0
geposted Sun 21 Apr 13 @ 12:09 pm
