Can someone help me for some reason when I scan my music it takes some time to complete for a size about 5mb it now take 46 second before the use to zip. So I tried different files and they all scan so slow help is appreciated thanks for the help.
geposted Tue 23 Apr 13 @ 7:29 am
You may have a slow drive 5400rpm, do a defrig on the drive first this should improve access speed. another issue may be the amount of available space in the hard drive, it should be 25% of the drives total capacity. If you play videos you should change the drive to a 7200Rpm speed to get better performance.
Good Luck...
Good Luck...
geposted Tue 23 Apr 13 @ 10:26 am
nothing has change on this computer same hard drive 2tb total I thing I used about 90gb they use to scan fast but not know
geposted Tue 23 Apr 13 @ 12:05 pm
Well, then defrig the drive or you might have to many services running in the background and need to shut what you don't need down.
Try Gamebooster to shut down services, it's free http://www.iobit.com/gamebooster.php
Good Luck
Good Luck
geposted Tue 23 Apr 13 @ 1:30 pm
